I found the following article about adding the Nagios Core URL in Notifications, https://support.nagios.com/kb/article/n ... s-765.html.
Is there an option to add the Nagios XI URL in Notifications instead?
Thanks in advance...John
Nagios XI URL In Notifications
Re: Nagios XI URL In Notifications
If the Contact has an associated user in Admin > Manage Users and is using the xi_host_notification_handler and xi_service_notification_handler notification commands you can follow this to adjust the notification templates:
https://assets.nagios.com/downloads/nag ... iables.pdf
If they are just Core Contacts (what we call contacts that do not have an associated user of the same name that use notify-host-by-email and notify-service-by-email commands), you would just follow the same KB you linked to but add the XI URL to it.
See here under the Notifications columns for what other macros are available for use by the notifications commands:
https://assets.nagios.com/downloads/nag ... olist.html
See here for reference:
https://assets.nagios.com/downloads/nag ... ntacts.pdf
website_url=http://YOURXISERVER/nagiosxi/https://assets.nagios.com/downloads/nag ... olist.html
So we are using the later (Core Contacts). I did try to using website_url=http://YOURXISERVER/nagiosxi/ as you had suggested, but the URL I'm receiving doesn't work. Note, we are using https, not http.
For example, using $SERVICEINFOURL$:
https://YOURXISERVER/nagiosxi/cgi-bin/e ... rvicecheck
Result: Not Found - The requested URL /nagiosxi/cgi-bin/extinfo.cgi was not found on this server.
However, using https://YOURXISERVER/nagios/cgi-bin/ext ... rvicecheck takes me to the service details in the Core interface.
For reference, this is the permalink for the service details in the XI interface:
https://YOURXISERVER/nagiosxi/?xiwindow ... est%3Dauto
John
John
I apologize, I misunderstood.
That's a bit more difficult because the hostname and servicedesc in the URL needs to be urlencoded, you could do this:
Then you could define your commands like this:
EDIT: To change the From address on the notifications you can change this portion of each command:
To:
cd /usr/local/nagios/libexec
wget https://gist.githubusercontent.com/cdown/1163649/raw/c3a30da93e94828918dcf3918e995726f445fc25/gistfile1.sh
chown apache.nagios gistfile1.sh
chmod 660 gistfile1.shCode: Select all
command_name notify-host-by-email
command_line . /usr/local/nagios/libexec/gistfile1.sh && /usr/bin/printf "%b" "***** Nagios Monitor XI Alert *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n\nHost Info URL: https://X.X.X.X/nagiosxi/includes/components/xicore/status.php?show=hostdetail&host=`urlencode '$HOSTNAME$'`\n" | /bin/mail -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
command_line . /usr/local/nagios/libexec/gistfile1.sh && /usr/bin/printf "%b" "***** Nagios Monitor XI Alert *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$\n\nService Info URL: https://X.X.X.X/nagiosxi/includes/components/xicore/status.php?show=servicedetail&host=`urlencode '$HOSTNAME$'`&service=`urlencode '$SERVICEDESC$'`&dest=auto\n" | /bin/mail -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
}Code: Select all
/bin/mail -sCode: Select all
/bin/mail -r 'Nagios XI <[email protected]>' -sRe: Nagios XI URL In Notifications
I was able to get the links working in our test environment. Thanks!!!
This topic can be considered closed.
