Use Nagios API to query the components under a BPI group
ccnadmin
Post by ccnadmin »
Understand that the a API for querying the BPI information
nagiosxi/api/v1/objects/bpi?
The result is a list of the BPI Groups, Host Groups and Service Groups, however there is no information of which Host Groups and Service Groups are under which BPI Group.
Is there a way or other API to get these information ?
pbroste
Re: Use Nagios API to query the components under a BPI group
Post by pbroste »
Hello @ccnadmin
Thanks for reaching out and you are correct that the BPI data can be exported via the api with:
curl -XGET "http://nagiosxi_ip/nagiosxi/api/v1/objects/bpi?apikey=<apikey>&pretty=1"
However, the option to pull data with Host or Sevice Groups within BPI is not available. I see that this feature has been requested and will add a bump to it.
Perry
ccnadmin
Post by ccnadmin »
Hi Perry,
Thank you for the fast response.
Hopefully the request will be answered soon as this will be a great help for company's Management to view the status of their monitored systems without accessing to the Nagios XI system.
pbroste
Post by pbroste »
Hello @ccnadmin
We have put in a feature request for this on your behalf, and here is the Nagios Change Log for your reference.
Perry
