List all Hosts using a specific Configuration Wizard?
Looking for suggestions on the best method to determine if any Hosts are using a specific Configuration Wizard, more specifically list all Hosts (if any) added using the Windows WMI Wizard.
Nagios XI 2024R2.2.1 (8 Servers)
Nagios Fusion 2024R1.0.2
Re: List all Hosts using a specific Configuration Wizard?
Hello @TBT
Thanks for reaching out, appears that the configs are created, and note that they "use xiwizard_windowswmi_service"
Sample config:
Perry
grep -Eir "xiwizard_windowswmi_service" /usr/local/nagiosxi/nom/checkpoints/nagioscore/* --color=always -B 2 --exclude=*templates.cfg | less -SRThanks,host_name Myhostnamehere
service_description CPU Usage
check_command check_xi_service_wmiplus!'administrator'!'password123'!checkcpu!-w '80' ->
max_check_attempts 5
check_interval 5
retry_interval 1
notification_interval 60
contacts nagiosadmin
_xiwizard windowswmi
register 1
Perry
@pbroste
I'm not seeing any results with that. I know there are at least a few checks using WMI as there is one particular service check in CCM with a command: $USER1$/check_wmi_plus.pl -H $HOSTADDRESS$ -A $ARG1$ -m $ARG2$ $ARG3$
That being said, the following returns results I'm looking for:
Thanks.
grep wmiplus /usr/local/nagios/etc/services/*Nagios XI 2024R2.2.1 (8 Servers)
Excellent find @TBT thanks for following up and providing the details. I will go ahead and lock this.
Perry
Perry
