NCPA Agent - API construction for process exceeding x.xx mem
Guyver1
Post by Guyver1 »
Was hoping someone would be able to assist in providing the correct options to filter for a process exceeding x.xx mem_vms or x.xx mem_rss
I can filter for our tomcat8 process no issues as this is straight forward:
However, when trying to add filters to filter for mem_vms or mem_rss => x.xx and setting it as a nagios check it either just sits there with the spinning circle
just sits there with the spinny circle:
does anyone have the correct settings to filter a specific process when it exceeds a memory value as a nagios check with warning and critical values please?
Guyver1
Re: NCPA Agent - API construction for process exceeding x.xx
Post by Guyver1 »
If I try this I just get stdout = 0 which is incorrect as it should alert
Guyver1
Post by Guyver1 »
I can do this from the "Live Data" option so it looks like what I want is possible:
https://imgur.com/2X1UxEk
