New releases
itunixops
New releases
Post by itunixops »
Is there a location where we can track when the next release of Nagios XI will be out? In addition is there a way to get onto your beta program? We were impressed by the recent Nagios XI 6 demo and want to get into the beta program to trial it.
gsmith
Re: New releases
Post by gsmith »
Hi
If you are currently running Nagios XI you can always hit the "Check for Updates" link to see if
you are running the current version of Nagios XI.
Other than that we don't post/predict an exact release date for an upcoming version.
Nagios XI is not available in a Beta version.
DonForigua
Re: New releases
Post by DonForigua »
Hello can say us, for example:
what system will not get support?
What versions of PHP will not get support?
will Php 8.0/8.1 compatible with future versions?
itunixops
Re: New releases
Post by itunixops »
Good question. I know we've phased out php 5.X support in favor of 7.X due to security. So far we've had no issues with it. Our RHEL8 migrations are proceeding well.
But in fairness I do have a couple of questions:
For those not running RHEL8 will php7 be a part of your distro package anytime soon?
What is the support like for PHP 8 as we may want to start testing there. Will this be a part of that or will future versions support it?
gsmith
Re: New releases
Post by gsmith »
Hi
This is what we currently support:
The developers are focused on Nagios XI 6.0, so adding support for anything not listed above
will be determined after the 6.0 release
