when i upgrade the testing nagios i get this error
Deprecated: Function get_magic_quotes_gpc() is deprecated in /usr/local/nagiosxi/html/includes/utils.inc.php on line 262
Deprecated: Array and string offset access syntax with curly braces is deprecated in /usr/local/nagiosxi/html/includes/components/ldap_ad_integration/adLDAP/src/classes/adLDAPUsers.php on line 520
Warning: session_name(): Cannot change session name when headers already sent in /usr/local/nagiosxi/html/includes/utils.inc.php on line 107
Warning: ini_set(): Headers already sent. You cannot change the session module's ini settings at this time in /usr/local/nagiosxi/html/includes/utils.inc.php on line 110
Warning: ini_set(): Headers already sent. You cannot change the session module's ini settings at this time in /usr/local/nagiosxi/html/includes/utils.inc.php on line 111
Warning: ini_set(): Headers already sent. You cannot change the session module's ini settings at this time in /usr/local/nagiosxi/html/includes/utils.inc.php on line 112
Warning: ini_set(): Headers already sent. You cannot change the session module's ini settings at this time in /usr/local/nagiosxi/html/includes/utils.inc.php on line 118
Warning: session_set_cookie_params(): Cannot change session cookie parameters when headers already sent in /usr/local/nagiosxi/html/includes/utils.inc.php on line 121
Warning: ini_set(): Headers already sent. You cannot change the session module's ini settings at this time in /usr/local/nagiosxi/html/includes/utils.inc.php on line 122
Warning: session_start(): Cannot start session when headers already sent in /usr/local/nagiosxi/html/includes/utils.inc.php on line 125
Warning: array_key_exists() expects parameter 2 to be array, null given in /usr/local/nagiosxi/html/includes/utils.inc.php on line 156
Warning: Cannot modify header information - headers already sent by (output started at /usr/local/nagiosxi/html/includes/utils.inc.php:262) in /usr/local/nagiosxi/html/includes/utils.inc.php on line 185
Warning: Cannot modify header information - headers already sent by (output started at /usr/local/nagiosxi/html/includes/utils.inc.php:262) in /usr/local/nagiosxi/html/includes/utils.inc.php on line 186
Nagios XI Upgrade Complete!
You can access the Nagios XI web interface by visiting:
http://192.168.1.118/nagiosxi/Code: Select all
PHP 7.4.27 (cli) (built: Dec 14 2021 17:17:06) ( NTS )
Copyright (c) The PHP Group
Zend Engine v3.4.0, Copyright (c) Zend Technologies
with Zend OPcache v7.4.27, Copyright (c), by Zend Technologies
