Is the all_partitions ncpa configuration mainly for the API and wizard? What does the parameter control. The default is True.
Thank you,
Vinod
Question on ncpa configuration field all_partitions
vappukuttan
Re: Question on ncpa configuration field all_partitions
When all_partitions is set to 0 it will try to only show physical devices instead of other devices such as pseudo, memory, duplicate, or inaccessible filesystems.
See the psutil link below for an explanation of the functionality:
Taken from here:
https://github.com/NagiosEnterprises/nc ... cfg.sample
# Display all mounted disk partitions
# (essentially setting all=True here: https://psutil.readthedocs.io/en/latest/#psutil.disk_partitions)
# Default: 1
all_partitions = 1https://github.com/NagiosEnterprises/nc ... cfg.sample
