MS-SQL Server Plugin
sikainfo
Post by sikainfo »
Hi there,
We do have a little problem with the MS-SQL Server Plugin.
RHEL 6.2 with all needes Packages
NAGIOS XI 2011 R3.2
There where some glitches with correctly connet to the testsserver but we could handle that.
Now the Plugin give back a silly reply. On commandline it looks like:
./check_mssql_server.py -H <someAdress> -I MSSQLSERVER -P 1433 -U NAGIOS -P passwd --averagewait
<someAdress>\MSSQLSERVER
OK:Average Wait Time is 16.0ms|Average_Wait_Time=16.0ms;;;;[/b]
The part with
is going to be displayed in the NAGIOS XI Interface, which is not very usefull, I would rather be happy to see only the rest of the message, ;-)
This behavior is only with the check_mssql_server.py the others work fine.
Thanks for helping here
Andy
Re: MS-SQL Server Plugin
I believe this has been updated in the new wizard. I am attaching a file that can be unzipped and placed in your plugin directory to replace the current plugin.
sikainfo
Post by sikainfo »
Thanks a lot, works fine now.
Regards Andy
Excellent.
