Plugin issue from monitoring server.
rijo.r
Post by rijo.r »
Hi all,
I have an issue with NTP plugin. getting plugin output on ubuntu local server. but getting wrong output on monitoring server with NRPE.
Note : this issue only on ubuntu (Working fine on RHEL and Cetos)
used plugin link :https://exchange.nagios.org/directory/P ... 29/details
check command in nrpe.cfg
command[checkntp]=/usr/lib/nagios/plugins/check_chrony.sh 5 10
"/usr/local/nagios/etc/nrpe.cfg" 371L, 12978C
plugin out on local server
:/usr/lib/nagios/plugins# /usr/lib/nagios/plugins/check_chrony.sh 5 10
OK - time is 0.000922904 slow of NTP Time
|Time Differences in=0.000922904
plugin out on remote server using NRPE.
[root@localhost plugins]# /usr/lib64/nagios/plugins/check_nrpe -H 192.168.191.134 -c checkntp
Please provide only number in the warining and critical values
requesting to provide a solution for this issue
gormank
Re: Plugin issue from monitoring server.
Post by gormank »
Is the checkntp command defined in nrpe.cfg on the 192.168.191.134?
What do you get when you run the following on 192.168.191.134?
grep checkntp /usr/local/nagios/etc/nrpe.cfg
Did you restart nrpe/xinetd?
It looks like the please message is in the check script and is getting something in the command definition it doesn't like.
rijo.r
Post by rijo.r »
Hi gormank,
Thanks for your response
check command is mentioned in nrpe.cfg and restarted the NRPE also.
we have getting the script out on local server but observing issue with NRPE on Ubuntu 20.04.3
please refer the below configurations and also I'm attaching the check_chrony script
nrpe.cfg configuration
allowed_hosts=127.0.0.1,::1,192.168.191.135
dont_blame_nrpe=1
root@user:/usr/lib/nagios/plugins# /usr/lib/nagios/plugins/check_chrony.sh 5 10
OK - time is 0.006876635 slow of NTP Time
|Time Differences in=0.006876635
from remote server with NRPE
[root@localhost ~]# /usr/lib64/nagios/plugins/check_nrpe -H 192.168.191.134 -c checkntp
NRPE v4.0.0
check_chrony.sh
(2.17 KiB) Downloaded 452 times
gormank
Post by gormank »
The command defined looks fine to me. My best guess is that there are two commands with the same name defined. Maybe try grepping the command name from nrpe.cfg and in any included files if nrpe.cfg has an include dir defined.
