Waiting for configuration verification Issue
I'm trying to set a configuration and I'm running into a stuck configuration verification.
I did a tail on the log file and I seem to be running into a permission issue. Any help would be much appreciated.
Here is the log print:
PHP Warning: PHP Startup: Unable to load dynamic library 'ixed.7.2.lin' (tried: /usr/lib64/php/modules/ixed.7.2.lin (/usr/lib64/php/modules/ixed.7.2.lin: cannot open shared object file: Operation not permitted), /usr/lib64/php/modules/ixed.7.2.lin.so (/usr/lib64/php/modules/ixed.7.2.lin.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
PHP Warning: require_once(/usr/local/nagiosxi/html/config.inc.php): failed to open stream: Operation not permitted in /usr/local/nagiosxi/cron/cmdsubsys.php on line 10
PHP Fatal error: require_once(): Failed opening required '/usr/local/nagiosxi/cron/../html/config.inc.php' (include_path='.:/usr/share/pear:/usr/share/php') in /usr/local/nagiosxi/cron/cmdsubsys.php on line 10
Moderator's Note: The profile has been shared with the support team but has been removed from the public forum.
Re: Waiting for configuration verification Issue
Please follow this KB article and let me know if that resolves the issue:
https://support.nagios.com/kb/article/n ... s-816.html
What is the output of these commands as root?
sestatus
umask
Please follow the attached guide for that:[Wed Jan 26 15:43:00.958533 2022] [proxy_fcgi:error] [pid 1313459:tid 140535952041728] (70007)The timeout specified has expired: [clientXXXXXXXX:49344] AH01075: Error dispatching request to : (polling), referer: https://XXXXXXXX/nagiosxi/includes/comp ... rofile.php
I reviewed the KB article. I was able wget the latest and SCP the tar to the server. I unpacked the tar and navigated to the directory. When I do a ./init.sh as root, there is no file or directory. I attached a screenshot. How should I proceed?
Here is the print from the commands you requested:
[root@hernn-nagi-001 ~]# sestatus
SELinux status: enabled
SELinuxfs mount: /sys/fs/selinux
SELinux root directory: /etc/selinux
Loaded policy name: targeted
Current mode: permissive
Mode from config file: permissive
Policy MLS status: enabled
Policy deny_unknown status: allowed
Memory protection checking: actual (secure)
Max kernel policy version: 33
[root@hernn-nagi-001 ~]# umask
0077
0077
The KB article lists this one as the one to use:
https://assets.nagios.com/downloads/nag ... est.tar.gz
The one you're using is the offline installer RPM package, please use the one above and it should work for you (you're not doing an install/upgrade, it's just installing the loaders from that package).
It was the one I used, however, I seem to be running into a new issue. How can I not have permission as root?ssax wrote:The KB article lists this one as the one to use:
The source install doesn't have all of the nagiosxi-*.rpm files in it, that's how I was able to tell.
You likely have noexec set on /tmp:
You can do this:
https://unix.stackexchange.com/q/347229
OR you can just do it outside of /tmp.
mount | grep noexechttps://unix.stackexchange.com/q/347229
OK, so I was able to complete the tasks you recommended. However, I don't think there was a change. I tried to submit the configuration and it continues to get stuck at validating configuration. I did a tail on the cmdsubsys.log and I seem to be getting the same errors. Is there a way to set a timestamp on this log so I can validate they are new and not stale?
Please create a ticket for this and include a link back to this forum thread so we can get a remote session scheduled:
https://support.nagios.com/tickets/
In that new ticket, attach your /etc/php.ini and your /etc/php.d/sourceguardian.ini file and the output of these commands:
Thank you!
ls -l /usr/lib64/php/modules/
rpm -qa | grep php
deweycoffman
Jonathon and I are working together on this issue. I was working this in a different thread. So the two are duplicates.
The "unable" to load and "failed to open" errors comes from fapolicyd not having all the PHP files in the /etc/fapolicyd/fapolicyd.trusted (see attached for file list, YOU CANNOT just add them to the files, but need to add them via the "fapolicy-cli --file add filename" command
see this link: https://access.redhat.com/documentation ... -hardening
I'm still working through the problem, this may not be a complete list.
