NCPA windows event viewer
btayl
Post by btayl »
I want to monitor the event viewer for a task scheduler for a event id 111
I know it falls under Application and Services logs > Microsoft > TaskSchedular > Operational
./check_ncpa.py -H UHMEDLRESPR1.umhs.med.umich.edu -t '$user9$' -P 5693 -M 'logs' -q 'name=TaskScheduler,severity=Information,event_id=111' --list
and I get this
"logs": [
"TaskScheduler": []
"logs"
How can i fix this ?
ssax
Dreams In Code
Re: NCPA windows event viewer
Post by ssax »
I'm investigating and will post an update shortly.
ssax
Dreams In Code
Post by ssax »
It's not working for me either.
When I right-click on the event log it shows this as the Full Name:
Microsoft-Windows-TaskScheduler/Operational
So I tried these with no success:
TaskScheduler
I also tried a bunch of other stuff, this may be a bug but I'm reaching out to QA/development to see what they have to say.
btayl
Post by btayl »
Any Updates?
craigq
Post by craigq »
I am also interested in this one. The filenames in the Windows event log directory actually have a %4 rather than a forward slash [%4 is translated by Event Viewer over to a forward slash]. I suspect something is getting mangled between the HTTP POST from the NCPA over to the Windows OS side of things. I've tried manipulating the POST to no avail (have been successful with space, %20 works). Any update on this matter would be appreciated.
ssax
Dreams In Code
Post by ssax »
I'm really wondering if this is what is going on:
https://stackoverflow.com/a/36535846
This is what mine shows:
PS C:\Program Files (x86)\Nagios\NCPA\plugins> powershell Get-EventLog -AsString -List
Active Directory Web Services
Application
DFS Replication
Directory Service
DNS Server
HardwareEvents
Internet Explorer
Key Management Service
Security
Setup
System
Windows PowerShell
ssax
Dreams In Code
Post by ssax »
I don't think that's it either as when I looked at the code I see it using win32evtlog in the NCPA code:
https://github.com/NagiosEnterprises/nc ... gs.py#L352
And this shows that win32evtlog can access those types:
https://stackoverflow.com/a/65417608
So I'm leaning towards bug with the slash or dashes throwing it off ala what @craigq mentioned.
