ssh-expect problem
niels
ssh-expect problem
Post by niels »
I'm trialling Nagios XI at the moment, and have come across a bug and fixed it. I'm documenting it here so that it can be fixed upstream.
I downloaded and installed the VMware 64bit appliance. Checked for updates (there were none).
I tried to setup an SSH Login check, and was told to run an install.sh script in /usr/local/nagiosxi/html/includes/configwizards/ssh-expect/scripts.
To get this script to work, I had to change the URL on line 17 to dl.fedoraproject.org and the release of that RPM to 5.4 instead of 5.3.
I also had to install the perl-Test-Base package via yum.
Cheers,
Niels
Re: ssh-expect problem
Thanks!
It has been updated.
