filesystem monitor only for status
preethu.d
Post by preethu.d »
Hi Team,
We have a requirement where we don't want to monitor disk space usage for FS mount points on servers , instead just want to be notified in case it’s unavailable/missing on that server. Please let me know if it’s feasible to monitor just the availability of FS mounts on servers instead of the disk usage parameter.
Below is the argument we are using currently
-t '<token number>' -P 5693 -M '<filesystempath>' -w '65' -c '80'
We don't need any alert if any breach in warning or critical threshold for disk uage. We need notification when this doesn't exist on the node.
Regards,
Preethu
pbroste
Re: filesystem monitor only for status
Post by pbroste »
Hello @preethu.d
Thanks for reaching out, and wanted to find out if using an alternate plugin would work for this instead. Found on our exchange plugins:
https://exchange.nagios.org/directory/Plugins/System-Metrics/....
Perry
preethu.d
Post by preethu.d »
Can we use the below argument ?
(without warning and critical threshold) will it monitor filesystem without alerting incase if disk is full ?
Also incase if the filesystem doesn't exist on the node it has to trigger the below unknown alert.
UNKNOWN: The node (<FS path> ? requested does not exist. You may be trying to access the '/' node.
Regards,
Preethu
ssax
Dreams In Code
Post by ssax »
What OS is the remote system you are checking?
If it is Windows, are these Windows Mapped Drives or actual disks on the system? See the Danger section at the top about mapped drives:
- Ignore that it's for NSClient++, it's the same for all agents as it's a Windows mapping disks per user session issue with mapped drives
https://docs.nsclient.org/reference/windows/CheckDisk/
preethu.d
Post by preethu.d »
Thanks for your message. I got the solution, You can lock the thread.
Regards,
Preethu
ssax
Dreams In Code
Post by ssax »
Thank you for your update, I'm glad you were able to resolve it! Locking the thread and marking as resolved.
