Error engine and timely manner
abe_780
Post by abe_780 »
Hello
We have some problem when we try to reschedule any check
If we check the monitor engine is critical
The others thinks work fine because if some check turns critical , nagios send mails and it turns ok it became green
Can you help us ?
Thanks in avance
