Installing, Failing on E-importnagiosql
boolean2
Post by boolean2 »
Having gotten to script "E-importnagiosql", I am almost there. Fedora core 8, 32b. I went to the actual login.php that is running and everything looks normal...I even tried using the previos user/pass commented lines to see if that was causing the Internal Server 500 error. Any ideas?
I receive the following:
nagiosxi]# ./E-importnagiosql
Starting httpd:
/tmp/nagiosxi/nagiosxi/basedir/scripts /tmp/nagiosxi
--2010-07-19 17:22:17-- http://localhost/nagiosql/index.php
Resolving localhost... 127.0.0.1
Connecting to localhost|127.0.0.1|:80... connected.
HTTP request sent, awaiting response... 500 Internal Server Error
2010-07-19 17:22:17 ERROR 500: Internal Server Error.
IMPORTING CONFIG FILES...Array
[0] => nagiosadmin.cfg
IMPORTING /usr/local/nagios/etc/import/nagiosadmin.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/nagiosadmin.cfg' -O nagiosql.import.monitoring
--2010-07-19 17:22:18-- http://localhost/nagiosql/admin/import.php
2010-07-19 17:22:18 ERROR 500: Internal Server Error.
SETUID ROOT OK
RESETTING PERMS
--2010-07-19 17:22:19-- http://localhost/nagiosql/index.php
2010-07-19 17:22:19 ERROR 500: Internal Server Error.
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/verify.php --post-data 'writeMonitoring=Go' -O nagiosql.export.monitoring
--2010-07-19 17:22:19-- http://localhost/nagiosql/admin/verify.php
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/verify.php --post-data 'writeAdditional=Go' -O nagiosql.export.additional
OUTPUT:
Nagios Core 3.2.0
Copyright (c) 2009 Nagios Core Development Team and Community Contributors
Last Modified: 08-12-2009
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Error: Cannot open config file '/usr/local/nagios/etc/contacttemplates.cfg' for reading: No such file or directory
RET: 254
/usr/local/nagiosxi/nom/checkpoints/nagioscore/errors /tmp/nagiosxi/nagiosxi/basedir/scripts
tar: Removing leading `/' from member names
ls: cannot access /usr/local/nagiosxi/nom/checkpoints/nagioscore/*.gz: No such file or directory
NO NOM SNAPSHOT FOUND!
/tmp/nagiosxi
mmestnik
Re: Installing, Failing on E-importnagiosql
Post by mmestnik »
What about your apache/httpd server? If you have some background that's what I'd be looking for, if you don't know then just start with where you can.
Check the server logs /var/log/httpd/error_log
Though I'm much more interested with what transpired to get this far, what was this server(perhaps it was in a brand new box from Dell, but I still have to ask you see.) prior to having XI installed for example.
