check_http not working
BanditBBS
Post by BanditBBS »
So something I don't understand at all here, curl works fine and check_http gives me socket timed out:
CURL:
[nagios@iss-chi-nag05 plugins]$ curl https://xxx.itconvergence.com
    <html>
        <script>
            document.cookie = "tg=; expires=Thu, 01 Jan 1970 22:00:00 GMT; path=/; secure";
            document.cookie = "sdesktop=; expires=Thu, 01 Jan 1970 22:00:00 GMT; path=/; secure";
            document.location.replace("/+CSCOE+/logon.html");
        </script>
    </html>
check_http:
[nagios@iss-chi-nag05 plugins]$ ./check_http -H xxx.itconvergence.com --ssl -v
SSL initialized
GET / HTTP/1.1
User-Agent: check_http/v2.4.0.git (nagios-plugins 2.4.0)
Connection: close
Host: xxx.itconvergence.com
Accept: */*
CRITICAL - Socket timeout
The only thing I can guess is even though I tell it --ssl it initially tries http and that is blocked by firewalls. I could be completely off base with that guess as well, I'm just at a loss!
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
pbroste
Re: check_http not working
Post by pbroste »
Hello @BanditBBS
Thanks for reaching out, want to find out if you tried the following example as a test:
/usr/local/nagios/libexec/check_http -H localhost -u https://ipchicken.com --ssl -v
If this is okay then run through this:
./check_http -H xxx -u itconvergence.com --ssl -v
    • xxx --> hostaddress or in my case localhost
Let us know how that looks.
Perry
BanditBBS
Post by BanditBBS »
Doing the first thing results in NagiosXI web page being loaded.
Doing the second thing results in invalid host name.
I'll PM you the actual full url so you can test.
BanditBBS
Post by BanditBBS »
Hey @pbroste
The example you gave in PM isn't a valid example. It's going to load the web page of the IP you used in -H arguement. If you add a -v to show verbose, you'll see it isn't loading my webpage but instead is loading whatever page is at that IP you used.
pbroste
Post by pbroste »
Hello @BanditBBS
My bad, thanks for bringing that to my attention, totally see what I did there.
Some more digging on this and we found where to make corrections:
First started out by testing via 'openssl' to get results:
openssl s_client -connect xxx-xx-xxx-xxxxxxx.xxxxxxxxce.com:443
  • With results: "write:errno=104"
Then added this to the 'openssl' to pass: (just providing for info)
  • Code: Select all
    openssl s_client -connect xxx-xx-xxx-xxxxxxx.xxxxxxxxce.com:443 -no_tls1_2
Then took that to correct the 'check_http' command:
  • Code: Select all
    /usr/local/nagios/libexec/check_http --ssl -S xxx-xx-xxx-xxxxxxx.xxxxxxxxce.com
The results:
  • HTTP OK: HTTP/1.0 200 OK - 1433 bytes in 3.425 second response time |time=3.425184s;5.000000;10.000000;0.000000 size=1433B;;;0
Regards,
Perry
BanditBBS
Post by BanditBBS »
Hey Perry,
Don't the --ssl and -S do the same exact thing, why are both required? I can validate it is working.
pbroste
Post by pbroste »
Hello @BanditBBS
Excellent, and yes you are correct that the -ssl and -S do the same.
Perry
