AD/LDAP not working
BanditBBS
AD/LDAP not working
Post by BanditBBS »
Getting this error:
Unable to authenticate: error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed (unable to get local issuer certificate)
We have imported the root and issue cert and have it set to use SSL. We try both ldap and AD and both return with the above error.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
ssax
Dreams In Code
Re: AD/LDAP not working
Post by ssax »
If your XI server OS version is RedHat/CentOS/Oracle:
Take the CA certs and put them in individual files in this directory:
- NOTE: They must have a .crt extension on the files
/etc/pki/ca-trust/source/anchors/
Then run these commands:
update-ca-trust extract
systemctl restart httpd php-fpm
Then test it again.
If your XI server OS version is Ubuntu/Debian:
/usr/local/share/ca-certificates/
sudo update-ca-certificates
systemctl restart apache2
Then test it again.
If that still doesn't resolve it (it should), please PM the full output of this command:
- Change your.ad_or_ldap.server before running
echo 'DONE' | openssl s_client -showcerts -connect your.ad_or_ldap.server:636
And attach or PM this file:
/etc/openldap/ldap.conf
BanditBBS
Post by BanditBBS »
That fixed it, but php-fpm wasn't even installed so I did install that as well.
Thanks a ton!
ssax
Dreams In Code
Post by ssax »
Glad that fixed it!
Are you on EL7? If so, just installing php-fpm wouldn't make it work, you would need to setup apache to use PHP-FPM for it to be used, I know it can be setup but I haven't personally done it on EL7.
Only EL8+ systems have PHP-FPM setup by default, I don't think Debian/Ubuntu have it setup at all without manual intervention/setup:
https://tecadmin.net/setup-apache-php-fpm-ubuntu-20-04/
BanditBBS
Post by BanditBBS »
Yeah, RHEL 7.
Thanks again
ssax
Dreams In Code
Post by ssax »
I'm not sure on the specifics but you should be able to look at how an el8 system is setup. Check your PMs.
