I'm using a Proxmox Server with LXC Container. In such an container i had installed deabian 11 std. After
apt update Code: Select all
apt upgradeCode: Select all
checking for nslookup syntax... Code: Select all
./configure --with-nagios-user=nagios --with-nagios-group=nagiosCode: Select all
curl https://assets.nagios.com/downloads/nagiosxi/install.sh | shnslookup is working normaly on the commandline.
Had anyone a idea what happens?
Kind regards
Michael
