Hello Experts,
I am using Nagios Core 4.4.5. And Have configured the network devices as per requirements. Here the main issue is the Availability Report's uptime as a CSV is coming in Seconds. I need that uptime in Human-readable format.
e.g Nagios shows the report as 86400 Seconds. I need it as 1d 0h 0m 0s.
So what changes should be done in the file(s) so that I can achieve my task. So No more manual work by calculating seconds into Hours, Days, Minutes, Seconds format.
Availability Report need in Human-readable format
yogeshpatel
avail.csv- Availability Report example
- (1.29 KiB) Downloaded 86 times
Re: Availability Report need in Human-readable format
The avail.cgi file is a binary so your best bet is probably to make a script that runs the report, grabs the CSV output, converts the time column from seconds to whatever you prefer and then saves the file.
yogeshpatel
Thanks for the reply.
Can you guide me for creating the shell script for report? As I am newbie in Nagios. If possible can't we directly change in avail.c file? and then compile the Nagios.
Yogesh P.
Yogesh P.
