Hi Support.
I have a nagiosXI with Mod gearman installed and configured. However, I found it cannot send notifications for those down/warning/unknown. but when it is recovered, the notification can be sent out. before mod gearman installed, everything was ok.
would you please take a look at it.
Can't send out notification when host is down
Re: Can't send out notification when host is down
Have you looked at using our NCPA functionality? mod_gearman is provided by a third-party, and our ability to support it is limited. However, NCPA is a more robust technology that Nagios provides and we can support this functionality fully. Please let me know if you need guidance to configure a host and/or service with NCPA so you can see the benefit of this technology.
Thank you!
Thank you!
