Report with threshold details
preethu.d
Post by preethu.d »
Hi Team,
Is there any option available in Nagios to generate a report with threshold value configured for each monitor.
I have many servers added in Nagios that has different threshold set for critical and warning severity for CPU, memory and disk monitor.
Is there any way I can pull a report with this threshold data ?
Regards,
Preethu
pbroste
Re: Report with threshold details
Post by pbroste »
Hello @preethu.d
Thanks for reaching out; perhaps an option to pull that data from the api or the database and parse the data you want. But we have not provided any set procedures to out-right pull threshold data. You can run through api for results, for example:
  • Code: Select all
    curl -XGET "https://yourhostaddresshere/nagiosxi/api/v1/config/service?apikey=yourapikeyhere&pretty=1"
Perry
preethu.d
Post by preethu.d »
Hi Perry,
I used API get request to pull the data. Thanks for the help. You can close the thread.
Regards,
Preethu
