Hi Support Team,
We are currently using Nagios XI 5.8.4 version in production(centos 7).
Nagios XI installation was done through OVA.
We have configured services at check interval 5 min, retry interval 5 min and max check attempts is 3.
From service now ticketing tool, we are polling only hard alerts to generate and close ticket.
Recently we have observed that, when a service comes up from down state it does not generate hard state on OK alert. It checks for only once that is soft state of OK alert(where it needs to check thrice so that it generates hard alert) and it does not checks for rest 2 attempts.
Due to which ticket are not auto closing in the service now system as it does not receives HARD state on OK alert from nagios server.
PFA for your reference.
Please help us to resolve this issue.
Thanks & Regards,
Supriya Lad.
Not generating hard state on OK alert
capgemtools
Supriya
Supriya
Re: Not generating hard state on OK alert
Hello @capgemtools
Thanks for reaching out, want to start off by running through reindexing.
Verify that the host and services look good in pre-flight with no errors in core by:
Please PM your updated system profile if the issue persists.
To send us your system profile.
Perry
pkill nagiosCode: Select all
/usr/local/nagiosxi/scripts/reconfigure_nagios.sh
/usr/local/nagios/bin/nagios -vvv /usr/local/nagios/etc/nagios.cfg
- Login to the Nagios XI GUI using a web browser.
- Click the "Admin" > "System Profile" Menu
- Click the "Download Profile" button
- Save the profile.zip file and send via Private Message
Perry
capgemtools
Hi Perry,
I have follwed the steps mentioned by you but see no errors.
Sharing you system profile via private message.
Currently we are on NagiosXI 5.8.4, so do we have to upgrade to latest version?
Supriya.
Supriya.
Supriya
Supriya
Hello @capgemtools
Thanks for following up and sending over the System Profile did not see anything that sticks out. Want to run through reindex and let us know how things look.
To reindex the Core Configuration Manager (CCM) configs by:
Perry
p.s.
rm -rf /usr/local/nagios/etc/import/*
Issue persists, please PM your system profile for us to review updates.
To send us your system profile.- Login to the Nagios XI GUI using a web browser.
- Save the profile.zip file and send as Private Message
Perry
p.s.
We're moving to a new support system!
The Nagios Answer Hub is a place where you can get help with technical questions from our experts. There, you can quickly open tickets and join discussion boards.
Request Nagios Answer Hub access here: https://info.nagios.com/answer-hub-access-new-users
After completing the access form, you will be given access to a portal where new tickets can be created. We will keep the old customer forum sections and ticket system available for current cases to be resolved.
capgemtools
Hi Perry,
I have followed steps mentioned by you but there are no errors.
Does it require us to upgrade nagiosxi to latest version to resolve this issue?
Supriya
Supriya
Hello @capgemtools
Thanks for following up and yes you are correct that an environment upgrade is highly suggested. Let's go ahead with the upgrade and have you open a new support ticket in the new Answer Hub.
Perry
Please let us link back to this support forum post so we can review the case details.We're moving to a new support system!
Perry
