SLA report only on Host
steph007
Post by steph007 »
When I do SLA report for a Host, I have also Services under that Host.
Is it possible to get the SLA report for the Host only?
steph007
Re: SLA report only on Host
Post by steph007 »
More information.
In the SLA report, I choose [Host Only] but it's not working, I got this error:
ERROR: You are not authorized to view this report.
Note
I'm connected with nagiosadmin
There is a bug in the SLA report that when it checks the permissions of the user when using the Host Only option and that is causing the permission issue.
I'll file a bug report so it will be fixed in a future XI update.
Thank you.
steph007
Post by steph007 »
Thanks!
Is-it fixed with 5.8.8?
kfanselow
Post by kfanselow »
Hi steph007,
The quick answer is no. Nagios XI 5.8.8 was released on the 8th of March. You can track XI releases and changes via the product changelog:
https://www.nagios.com/downloads/nagios-xi/change-log/
Thanks and Best Regards,
Keith
