<?php ?><?php // Copyright (c) 2008-2021 Nagios Enterprises, LLC. All rights reserved. ?><?php
if(!function_exists('sg_load')){$__v=phpversion();$__x=explode('.',$__v);$__v2=$__x[0].'.'.(int)$__x[1];$__u=strtolower(substr(php_uname(),0,3));$__ts=(@constant('PHP_ZTS') || @constant('ZEND_THREAD_SAFE')?'ts':'');$__f=$__f0='ixed.'.$__v2.$__ts.'.'.$__u;$__ff=$__ff0='ixed.'.$__v2.'.'.(int)$__x[2].$__ts.'.'.$__u;$__ed=@ini_get('extension_dir');$__e=$__e0=@realpath($__ed);$__dl=function_exists('dl') && function_exists('file_exists') && @ini_get('enable_dl') && !@ini_get('safe_mode');if($__dl && $__e && version_compare($__v,'5.2.5','<') && function_exists('getcwd') && function_exists('dirname')){$__d=$__d0=getcwd();if(@$__d[1]==':') {$__d=str_replace('\\','/',substr($__d,2));$__e=str_replace('\\','/',substr($__e,2));}$__e.=($__h=str_repeat('/..',substr_count($__e,'/')));$__f='/ixed/'.$__f0;$__ff='/ixed/'.$__ff0;while(!file_exists($__e.$__d.$__ff) && !file_exists($__e.$__d.$__f) && strlen($__d)>1){$__d=dirname($__d);}if(file_exists($__e.$__d.$__ff)) dl($__h.$__d.$__ff); else if(file_exists($__e.$__d.$__f)) dl($__h.$__d.$__f);}if(!function_exists('sg_load') && $__dl && $__e0){if(file_exists($__e0.'/'.$__ff0)) dl($__ff0); else if(file_exists($__e0.'/'.$__f0)) dl($__f0);}if(!function_exists('sg_load')){$__ixedurl='http://www.sourceguardian.com/loaders/download.php?php_v='.urlencode($__v).'&php_ts='.($__ts?'1':'0').'&php_is='.@constant('PHP_INT_SIZE').'&os_s='.urlencode(php_uname('s')).'&os_r='.urlencode(php_uname('r')).'&os_m='.urlencode(php_uname('m'));$__sapi=php_sapi_name();if(!$__e0) $__e0=$__ed;if(function_exists('php_ini_loaded_file')) $__ini=php_ini_loaded_file(); else $__ini='php.ini';if((substr($__sapi,0,3)=='cgi')||($__sapi=='cli')||($__sapi=='embed')){$__msg="\nPHP script '".__FILE__."' is protected by SourceGuardian and requires a SourceGuardian loader '".$__f0."' to be installed.\n\n1) Download the required loader '".$__f0."' from the SourceGuardian site: ".$__ixedurl."\n2) Install the loader to ";if(isset($__d0)){$__msg.=$__d0.DIRECTORY_SEPARATOR.'ixed';}else{$__msg.=$__e0;if(!$__dl){$__msg.="\n3) Edit ".$__ini." and add 'extension=".$__f0."' directive";}}$__msg.="\n\n";}else{$__msg="<html><body>PHP script '".__FILE__."' is protected by <a href=\"http://www.sourceguardian.com/\">SourceGuardian</a> and requires a SourceGuardian loader '".$__f0."' to be installed.<br><br>1) <a href=\"".$__ixedurl."\" target=\"_blank\">Click here</a> to download the required '".$__f0."' loader from the SourceGuardian site<br>2) Install the loader to ";if(isset($__d0)){$__msg.=$__d0.DIRECTORY_SEPARATOR.'ixed';}else{$__msg.=$__e0;if(!$__dl){$__msg.="<br>3) Edit ".$__ini." and add 'extension=".$__f0."' directive<br>4) Restart the web server";}}$__msg.="</body></html>";}die($__msg);exit();}}return sg_load('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 thoughts ?[zeus@chunk ~]$ apachectl status
* httpd.service - The Apache HTTP Server
Loaded: loaded (/usr/lib/systemd/system/httpd.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2022-03-14 06:39:44 EDT; 7min ago
Docs: man:httpd(8)
man:apachectl(8)
Main PID: 1713 (httpd)
Status: "Total requests: 8; Current requests/sec: 0; Current traffic: 0 B/sec"
CGroup: /system.slice/httpd.service
|-1713 /usr/sbin/httpd -DFOREGROUND
|-1823 /usr/sbin/httpd -DFOREGROUND
|-1824 /usr/sbin/httpd -DFOREGROUND
|-1825 /usr/sbin/httpd -DFOREGROUND
|-1827 /usr/sbin/httpd -DFOREGROUND
|-1828 /usr/sbin/httpd -DFOREGROUND
|-2568 /usr/sbin/httpd -DFOREGROUND
|-2571 /usr/sbin/httpd -DFOREGROUND
`-2572 /usr/sbin/httpd -DFOREGROUND
Mar 14 06:39:44 chunk.dmz.spf.nawcad.navy.mil systemd[1]: Starting The Apache HTTP Server...
Mar 14 06:39:44 chunk.dmz.spf.nawcad.navy.mil systemd[1]: Started The Apache HTTP Server.
[zeus@chunk ~]$ apachectl configtest
Syntax OK
