Hi
I need to monitor windows services(like CPU load, memory usage etc.), so I have installed Nagios monitoring tool. The installation is complete and 'check_nt' plugin is also installed. Upto this no error is there, but while executing scripts with agent NSClient++ 'Connection refused by host' error still persists.
./check_nt -H 10.112.32.78 -p 1248 -v MEMUSE -w 80 -c 90
Socket timeout after 10 seconds
I have verified that nagios is working correctly, as under.
Nagios Core 3.4.1
Last Modified: 05-11-2012
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config file '/usr/local/nagios/etc/objects/commands.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/timeperiods.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/templates.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/localhost.cfg'...
Checking services...
Checked 8 services.
Checking hosts...
Checked 1 hosts.
Checking host groups...
Checked 1 host groups.
Checking service groups...
Checked 0 service groups.
Checking contacts...
Checked 1 contacts.
Checking contact groups...
Checked 1 contact groups.
Checking service escalations...
Checking service dependencies...
Checked 0 service dependencies.
Checking host escalations...
Checked 0 host escalations.
Checking host dependencies...
Checked 0 host dependencies.
Checking commands...
Checked 24 commands.
Checking time periods...
Checked 5 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 0
Total Errors: 0
M new to nagios,
thanks in advance
Nagios - Connection refused & Socket timeout
PaulRajeshMEzra45
