CHECK_NRPE: Error - Could not complete SSL handshake.
deepakd
Post by deepakd »
I am getting issue while configuring the nrpe through xinetd
It gives me
I have done below configuration:
/etc/xinetd/npre
# default: on
# description: NRPE (Nagios Remote Plugin Executor)
service nrpe
flags = REUSE
socket_type = stream
port = 5666
wait = no
user = icinga
group = icinga
server = /usr/local/icinga/bin/nrpe
server_args = -c /usr/local/icinga/etc/nrpe.cfg --inetd
log_on_failure += USERID
disable = no
cps = 100 30
per_source = UNLIMITED
instances = UNLIMITED
only_from = 127.0.0.1 10.0.13.82
cat /usr/local/icinga/etc/nrpe.cfg|grep allowed
# that are allowed to talk to the NRPE daemon. Network addresses with a bit mask
allowed_hosts=127.0.0.1,10.0.13.82
cat /etc/services |grep 566
nrpe 5666/tcp # Nagios Remote Plugin Executor
I have tried all things mention in link
https://supportmonk.com/2020/09/09/chec ... s%20server.
aslo tried
dont_blame_nrpe=1 in /usr/local/icinga/etc/nrpe.cfg
added the IPs in hosts.allow.
I have tried the below command while installing nrpe:
./configure --prefix=/usr/local/icinga --with-nagios-user=icinga --with-nagios-group=icinga --with-nrpe-user=icinga --with-nrpe-group=icinga --with-ssl=/usr/bin/openssl --with-ssl-lib=/usr/lib/x86_64-linux-gnu
I douubt on network,firewall or openssl for this issue. Is the below version supported the icinga
By the i am running on the nrpe on Ubuntu.
openssl version
OpenSSL 1.1.1f 31 Mar 2020
Can you please help me, what I missed to check.
nrpe.cfg
nrpe cfg on path usr local
(8.02 KiB) Downloaded 135 times
