No data in performance graph showing 0 value
dimsum
Post by dimsum »
I have a problem with the performance graph is not working. it's showing 0 value anytime. but I can get this graph in an old graph with mrtg. see the pictures attached. any idea to fix this issue.
Thank you
gsmith
Re: No data in performance graph showing 0 value
Post by gsmith »
We're moving to a new support system!
The Nagios Answer Hub is a place where you can get help with technical questions from our experts. There, you can quickly open tickets and join discussion boards.
Request Nagios Answer Hub access here: https://info.nagios.com/answer-hub-access-new-users
After completing the access form, you will be given access to a portal where new tickets can be created. We will keep the old customer forum sections and ticket system available for current cases to be resolved.
Go to the Answer Hub
