Nagios plugins with Golang
RickyReyesmatrina
Post by RickyReyesmatrina »
was thinking of a way to learn golang and at the same time to solve some perf issue
should I rewrite all my nagios agents with golang ?
atc0005
Re: Nagios plugins with Golang
Post by atc0005 »
That's a significant task to pursue. I'd instead suggest looking at the smallest usable plugin you can create and implement that. As you gain confidence you can implement more complex plugins.
I took a similar path and learned a lot from the process.
