Email Notifications
cvc.lukes
Email Notifications
Post by cvc.lukes »
I'm having an issue with setting up email notifications. when I check in the nagios.log file, I see this message
[1656511916] wproc:   early_timeout=0; exited_ok=1; wait_status=19200; error_code=0;
[1656511916] wproc:   stderr line 01: sendmail: invalid option -- 's'
[1656511916] wproc:   stderr line 02: sendmail: invalid option -- 's'
[1656511916] wproc:   stderr line 03: sendmail: fatal: usage: sendmail [options]
I have tried to test manually and confirmed the exact same thing happens.
[root@nagios ~]# /usr/bin/printf "%b" "test" | /usr/sbin/sendmail -s "test subject" [email protected]
Does anyone know if the sendmail options have changed? I've read through the manual about 4 times now and I don't see anything calling out subject anymore.
gormank
Re: Email Notifications
Post by gormank »
On my RHEL 7.x systems sendmail is actually postfix, and a test gives the same result.
You might try using SMTP instead of sendmail.
cvc.lukes
Post by cvc.lukes »
gormank wrote:You might try using SMTP instead of sendmail.
Thanks. I'm not using RHEL but CentOS and ended up switching from sendmail to mailx and it works great now.
