I have an application running with python and django. The users login details for this application are saving to a mysql table. Once a user login to app, it will be updated on this table. So now I need to print "CRITICAL" status on nagios if there is no activity on the app for two days, otherwise print "OK" status on nagios. is it possible to omegle.2yu.co implement omeglz echat with nagios?
Any help would be appreciated.
Thanks in advance
Nagios Monitoring
RajeshEzrado
Nagios Monitoring
Re: Nagios Monitoring
You can create a plugin script to do the check, return the status and print a message.
