Dear Nagios,
When I run command check_mysql then It gives the following error:
[root@nagios libexec]# ./check_mysql
./check_mysql: error while loading shared libraries: libmysqlclient.so.18: cannot open shared object file: No such file or directory
My mariadb up-to-date to version 10.3.32 and it used libraries libmysqlclient.so.21 and libmysqlclient.so.21.1.26, does the new plugin 2.3.3 support libmysqlclient.so.21.
I used nagios plugins 2.0.3
Could someone asap give me an answer?
With kind regards from,
Scorpioking22
Nagios plugins check_mysql No such file or directory.. check
scorpioking22
