How do we monitor a remote service running on a machine using Nagios. I have created a cfg file as follows:
command_name check_http
command_line /usr/lib64/nagios/plugins/check_http -H $HOSTADDRESS$ -p 8082
Now when I reload the configuration file, it throws following error:
Warning: Duplicate definition found for command 'check_http' (config file '/etc/nagios/servers/cfbase-prod.cfg', starting on line 19)
Error: Could not add object property in file '/etc/nagios/servers/cfbase-prod.cfg' on line 20.
Error processing object config omegle.2yu.co files!
I am not able to figure out omeglz echat what is the problem. Please help!
Monitor a service running on a port other than 80 in Nagios
BettyRNorahDeniels
Last edited by BettyRNorahDeniels on Mon Aug 29, 2022 6:59 am, edited 1 time in total.
Re: Monitor a service running on a port other than 80 in Nag
You're redefining check_http so it gives an error. Use a new name.
Sorry,
I should have said create a service that uses the check_http command, not create a new command.
JernalinSadhoo
You can specify the port number directly in the command but you will must create one command per tested port.
Or you can create a custom variable to store the port number , with your example:
define host {
use linux-server
host_name cfbase-prod
alias cfbase-prod
address x.x.x.x
contacts admin
service_description HTTP
check_command check_http
contacts admin
check_interval 1
_port_number 8083
And on your command you can inherite of this variable like this :
command_line $USER1$/check_http -I $HOSTADDRESS$ -p $_SERVICEport_number$ $ARG1$
You must prepend _service for a service or _host for a host to use your echatspin echatrandom variable in a command.
define host {
use linux-server
alias cfbase-prod
address x.x.x.x
contacts admin
contacts admin
check_interval 1
_port_number 8083
