Monitoring Amazon Instances controlled by auto scaling
shaun666
Post by shaun666 »
It is practical to monitor Amazon instances which are controlled by Auto scaling?
They are by nature ephemeral, so is there a way to tell the Nagios server to delete a system when an Autoscaler terminates an instance?
TIA
Shaun
mguthrie
Re: Monitoring Amazon Instances controlled by auto scaling
Post by mguthrie »
We actually have another customer who's doing exactly what you describe. They did some of their own home-grown scripts for detecting the new instances, but as far as the XI side of things, you can use the doc below to auto scale:
http://library.nagios.com/library/produ ... -nagios-xi
shaun666
Post by shaun666 »
Very helpful, and just what I needed.....
Thanks for prompt and accurate advice.
Shaun
mguthrie
Post by mguthrie »
You're welcome : )
