I'm learning the ropes with librenms and developing a nagios plugin to obtain flexpool performance information for my mining operations.
This part of the Services readme is what I see:
omegle instagram video download
Please create an issue on GitHub with the debug information from the script and let us know which datasources should be grouped together if you come across a check script that might benefit from having some datasources graphed together.
Does that imply I can't complete the task myself? Assuming that all performance data would be plotted on the same chart, I have the script returning separate groupings of performance data dependent on flags, but this isn't the case with echatspin echatrandom.
Performance metrics from the Nagios plugin in a single graph
danylokerrion
