NAGIOS XI Login Issue
Post Reply
syntelgcc
Post by syntelgcc »
Hi Team,
we are facing NAGIOS XI login issue. when we are giving correct credentials it was redirecting to same login page.
ssunga
Re: NAGIOS XI Login Issue
Post by ssunga »
Hey @syntelgcc, thanks for reaching out.
Can you tell me more about the OS you are using, the Nagios version, if this happens across other browsers, and if this issue is still occurring? Thank you.
Nanasi12
Post by Nanasi12 »
It sounds like you're experiencing a common issue where the Nagios XI login screen keeps redirecting back to itself even after entering the correct credentials waffle
bbahn
Post by bbahn »
@syntelgcc,
If you go to the IP address of your Nagios XI server (http://X.X.X.X instead of http://X.X.X.X/nagiosxi), and then continue to Nagios XI from that page, the problem will usually be solved. If that doesn't work, you can clear your cookies and site data for your Nagios XI server and try again. How to clear cookies and browsing data in Chrome, Safari, Firefox and Edge
Post Reply
