We are using Nagios to monitor our network with great success. However, we have a syslog for critical application errors and while I set up check_log, it doesn't seem to work as well as omegle.2yu.co monitoring a device.
The issues are:
It only shows the last entry
There doesn't seem to be a way to acknowledge the critical error and return the monitor to a good state
Is nagios the wrong tool, or are we just not setting up the service monitoring right?
Here are my entries
# log file
command_name check_log
command_line omeglz echat $USER1$/check_log -F /var/log/applications/appcrit.log -O /tmp/appcrit.log -q ?
# Define the log monitering service
name logfile-check ;
use generic-service ;
check_period 24x7 ;
max_check_attempts 1 ;
normal_check_interval 5 ;
retry_check_interval 1 ;
contact_groups admins ;
notification_options w,u,c,r ;
notification_period 24x7 ;
register 0 ;
use logfile-check
host_name localhost
service_description CritLogFile
check_command check_log
How do I use Nagios to monitor a log file
HarengaWoltraz
Last edited by HarengaWoltraz on Tue Sep 13, 2022 3:09 am, edited 1 time in total.
CarlosCarrancom
Re: How do I use Nagios to monitor a log file
For monitoring logs with Nagios, typically the log checker will return a warning only for newly discovered error messages each time it is invoked (so it must retain some state in order to know to ignore them on subsequent runs). Therefore I usually set:
is_volatile 1
This causes Nagios to send out the alert immediately, but only once, and then go back to normal.
My favorite log checker is logwarn, but I'm biased because I wrote it myself after not finding any existing ones that I liked. The logwarn package includes a Nagios plugin.
is_volatile 1
