check_sip
Post Reply
gareth129349
check_sip
Post by gareth129349 »
Hi All,
I'm having a little trouble getting the check_sip plugin to work.
If I run the command from the terminal it works fine
[root@nagios objects]# /usr/local/nagios/libexec/check_sip -u sip:[email protected] -H II.PP.AA.SS
SIP/2.0 200 OK, 3.555702 seconds response time, cnt=4|rtt=3.555702s;cnt=4;0.5s;1s;0:10; code=200
From the nagios check i see -
My Config -
/usr/local/nagios/etc/objects/commands.cfg
        command_name    check_sip
        command_line    $USER1$/check_sip -u $ARG1$ -H $HOSTADDRESS$ -w 5
        use                             router-service         ; Name of service template to use
        host_name                       CallSwitch
        service_description             SIP CHECK MY SERVER
        check_command                   check_sip!sip:[email protected]!II.PP.AA.SS
The os is cent os 7
Can anyone help?
gareth129349
Re: check_sip
The code under /usr/local/nagios/etc/objects/commands.cfg was set to $HOSTADDRESS$ and needed changing to $ARG2$
        command_line    $USER1$/check_sip -u $ARG1$ -H $ARG2$
It's now working :)
Post Reply
