Need help to install check_mysql_health on Nagios
Post Reply
jazzadmin
Post by jazzadmin »
We are unable to install check_mysql_health. Please provide us the steps or guide to do the needful.
https://exchange.nagios.org/directory/P ... th/details
gormank
Re: Need help to install check_mysql_health on Nagios
Post by gormank »
You probably want to use the instructions with the plugin and post what trouble you're having.
cdevidal
Post by cdevidal »
That plugin isn't owned or produced by Nagios, you'll need to contact the script author for help. However, I was able to use the check_mysql plugin which came with Ubuntu to monitor my MySQL, no problems.
By the way, I don't work for Nagios. Just a user like you.
Post Reply
