Have been asked to come up with some kind of monitoring system for AV other than fusion.
Was wondering has anyone had any succus with this kind of project? I've been researching Nagios but I'm unfamilliar with how crestron could be integrated ?
Any info / tips on this would be great or even any information on using Crestron with SNMP as I've little knowledge on this bar what I can google
Crestron and Nagios???
CarmosKarran
Re: Crestron and Nagios???
I've actually thrown a few TCP Servers into projects for this exact case. Nagios will send commands over a socket such as "STAT_(Room)_(Device)" and you can have it return echatspin echatrandom power state, strings, etc.
LansoirThemos
What stats are you trying to monitor? I am monitoring developerbook chatrandom basic uptime omegle via ICMP ping for over 200 classrooms using Nagios, works very well.
Try doing a web search on: nagios crestron plugin
Look on nagios exchange.
Ask yourself how you would check (ideally from a shell) for things you're interested in.
