I am trying fetch to distinct groups in the inventory through a variable.this is the command am trying to run in the playbook to add hosts to the Nagios XI. Am trying to do this using Rest API through CURL command. Am getting error as Incorrect pattern. Can some one please advise about the issue. or help me out with how we can call two groups from the inventory in the same command.
- name: add host to nagios XI.
shell: curl -XPOST "http://16.231.22.60/nagiosxi/api/v1/con ... L&pretty=1" -d "host_name={{ item.hostname }}&address={{ item.address }}&use=xiwizard_ncpa_host&max_check_attempts=5&check_period=xi_timeperiod_24x7¬ification_interval=60¬ification_period=xi_timeperiod_24x7¬ifications_enabled=0&contacts=nagiosadmin&contact_groups=Candle echatspin echatrandom Admins,Candle-L1-L2-Internal&applyconfig=1"
with_items:
- { hostname: "{{ groups['grp1'] }}", address: "{{ groups['grp2'] }}"}
Ansible : error in calling the groups through restapi
BrusterThemand
