I want to add a contact group to specific services and hosts
How do i accomplish that task the easiest way?
Modify contact group for multiple services
Re: Modify contact group for multiple services
Thanks for your reply.
I don't think this will solve my problem.
With this tool i create groups but not attach them to hosts or services.
I have about 4 different contact groups and i want to attach them to about 1500 hosts and services so the users receives emails from the checks.
Now i must modify every service and host manually, and attach a contact group to it. (means lot of work)
Attached is a CCM Beta 0.5 which has the feature your are looking for. It can be added as a component in XI.
Then
Configure -> CCM Beta -> Tools -> Bulk Modifications
Then
Thank you, the plugin works fine!
