Server time offset
Baptist39
Server time offset
Post by Baptist39 »
I have a time problem on my nagios server.
I noticed that I had quite a few alerts with this problem, but I don't understand the discrepancy.
Currently, it is 3:41 pm but on the server :
Monday 14 November 2022, 16:03:06 (UTC+0100)
I have already made several changes, but I would like to know if this can be managed from the Nagios interface?
Because I still can't stabilize the time...
I am on Debian 10.13 Buster.
If you have a solution that would be great...
Thank you!
gormank
Re: Server time offset
Post by gormank »
You need to sync to a time source using ntpd or chrony at the OS level, not nagios. Also set the timezone in the OS.
Baptist39
Post by Baptist39 »
I had already tested with ntp, without success, then with timedatectl. I'll try Chrony, I didn't know, thanks.
Hoping to do better!
Baptist39
Post by Baptist39 »
Subject closed ! Thanks.
I think that uninstalling ntpd solved the problem.
lunadam
Post by lunadam »
cnorell
Developer
Post by cnorell »
As this issue was resolved - happy to see it was - I'm going to lock the thread. If you have any other issues feel free to open a new thread.
Best Regards,
Cory Norell
