problem update to 3.2
b.vandijk
Post by b.vandijk »
I want to update our current Nagios XI 3.1 install.
we followed this document
after i run the ./upgrade command the process stops with the following message
*** Exfoliation theme installed ***
NOTE: Use 'make install-classicui' to revert to classic Nagios theme
make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios'
make install-basic
make[1]: Entering directory `/tmp/nagiosxi/subcomponents/nagioscore/nagios'
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/libexec
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/var
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/var/archives
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/var/spool/checkresults
if [ no = yes ]; then \
                /usr/bin/install -c -m 664 -o nagios -g nagios p1.pl /usr/local/nagios/bin; \
        fi;
*** Main program, CGIs and HTML files installed ***
You can continue with installing Nagios as follows (type 'make'
without any arguments for a list of all possible options):
  make install-init
     - This installs the init script in /etc/rc.d/init.d
  make install-commandmode
     - This installs and configures permissions on the
       directory for holding the external command file
  make install-config
     - This installs sample config files in /usr/local/nagios/etc
Running configuration check...done.
Stopping nagios: .done.
Starting nagios: done.
Saving old crontab to /tmp/nagios.crontab.orig.4...
no crontab for nagios
what went wrong ??
Re: problem update to 3.2
You can do the following
cd /tmp/nagiosxi
cat /dev/null > uninstall-crontab-nagios
cat /dev/null > uninstall-crontab-root
./upgrade
Let us know if you still don't get to the end of the upgrade script
b.vandijk
Post by b.vandijk »
awesome, that solved my problem, running on 3.2 now!
