We plan to integrate an Sensor in our IT Envirionment based on 1-wire sensors with an ow-server.
Unfortunatley the Company which has build the Ow-Server doesn't offer any traps in the MIB.
So i tried to create an MIB trap on myself
My reference is the Main Doku from snmptt
Here is the nagios trap log:
trap.log:
Mon Jul 9 11:28:33 2012: Unknown trap (.1.3.6.1.4.1.31440.0.6) received from 192.168.23.10 at:
Value 0: 192.168.23.10
Value 1: 192.168.23.10
Value 2: 115:5:24:30.31
Value 3: .1.3.6.1.4.1.31440.0.6
Value 4: 192.168.23.10
Value 5: public
Value 6: .1.3.6.1.4.1.31440
Value 7:
Value 8:
Value 9:
Value 10:
Ent Value 0: .1.3.6.1.4.1.31440.2.2.1.1.4=1
MonJul 9 11:31:25 2012: Unknown trap (.1.3.6.1.4.1.31440.0.6) received from 192.168.23.10 at:
Value 2: 121:10:59:44.32
Value 5: public
Value 7:
Value 8:
Value 9:
Value 10:
Ent Value 0: .1.3.6.1.4.1.31440.2.2.1.1.4=2
Here is the snmptt conf for the trap:
Event wateralertBOWSERVER .1.3.6.1.4.1.31440.0.6 "Status Events" Critical
FORMAT user intervention is needed
EXEC /usr/local/nagios/libexec/submit_check_result localhost "Water Alert" 2 "Water $3 "
MATCH $Ent Value 0: 1
Variables:
Value 2: 15:2:45:35.36
Value3: .1.3.6.1.4.1.31440.0.6
Value 5: public
Value 7:
Value 8:
Value 9:
Value 10:
SDESC
ow-server alert
EDESC
Event wateralertAOWSERVER .1.3.6.1.4.1.31440.0.6 "Status Events" INFORMATIONAL
FORMAT all ok
EXEC /usr/local/nagios/libexec/submit_check_result localhost "Water Alert" 2 "Water $3 is ok"
MATCH $Ent Value 0: 2
Variables:
Value 2: 33:14:58:42.84
Value 5: public
Value 7:
Value 8:
Value 9:
Value 10:
SDESC
ow-server alert
EDESC
works:
- Other snmp traps which were generated by snmpttconvertmib and used with the snmp check result plugin
dosen't work:
- The own generated trap ( won't be recognised anymore the trap apperars in the unknown trap log all the time)
I think it has sth. to do with the match variable. But I'm not so familar with the perl syntax.
May someone could help me.
best regards john
