I'm trying to install xi-5.9.1 on Ubuntu 22 but fails with this error after running fullinstall
Files=16, Tests=33, 1 wallclock secs ( 0.04 usr 0.01 sys + 0.61 cusr 0.08 csys = 0.74 CPU)
Result: FAIL
Failed 16/16 test programs. 32/33 subtests failed.
make: *** [Makefile:861: test_dynamic] Error 255
ERROR: Subcomponent 'extraplugins' installation failed - exiting.
Subcomponents installation failed - exiting
Nagios XI fails install on Ubuntu 22
Re: Nagios XI fails install on Ubuntu 22
Result: FAIL
Then I log out/in the host requires a reboot, fails to reboot causes a Kernel panic - Not syncing. I this point I have to reinstall the OS
Result: FAIL
Read the log file in the in the dir where the fullinstall script is located.
