ncpa on deb11
nagnerd
ncpa on deb11
Post by nagnerd »
Does ncpa not support Debian 11? If not, do you know when it will?
kvang
Re: ncpa on deb11
Post by kvang »
Hi nagnerd,
Yes, NCPA supports Debian 11. You can check out the following link for more info. Be sure to change the linux option to Debian 11. I will now lock this post.
phred
Re: ncpa on deb11
Post by phred »
Hey @nagnerd:
NCPA v3 supports Debian v9+. The beta, which is actually quite solid, can be downloaded here: https://www.nagios.org/ncpa/#downloads
Scroll down to the bottom of the page to see the beta downloads.
The production version should be out within a few weeks, plus or minus, as I understand it.
