Error When Setting Up Contacts.cfg
Post Reply
ijared
Post by ijared »
I am using Nagios Core 4.4.6 on Ubuntu 22.04 LTS. I'm trying to setup email notifications but I run into an error whenever I go to verify that my configs are correct. Postfix is already configured properly and sending mail out but I haven't been able to get this working.
Issue when running verification command
Checking objects...
        Checked 26 services.
        Checked 23 hosts.
        Checked 4 host groups.
        Checked 0 service groups.
Error: Contact 'jdoe' has no service notification commands defined!
Warning: Contact 'jdoe' has no service notification time period defined!
        Checked 1 contacts.
        Checked 1 contact groups.
        Checked 24 commands.
        Checked 5 time periods.
        Checked 0 host escalations.
        Checked 23 hosts
        Checked 0 host dependencies
        Checked 5 timeperiods
Checking misc settings...
Total Warnings: 1
Total Errors:   1
Contacts.cfg
define contact {
        contact_name                      jdoe
        alias                                    John Doe
        email                                   [email protected]
        host_notification_period                24x7
        host_notification_options               d,u,r,f,s
        host_notification_commands              notify-host-by-email
# CONTACT GROUPS
# We only have one contact in this simple configuration file, so there is
# no need to create more than one contact group.
define contactgroup {
    contactgroup_name       admins
    alias                   Nagios Mailing List
    members            jdoe
Commands.cfg
# COMMANDS.CFG - SAMPLE COMMAND DEFINITIONS FOR NAGIOS 4.4.6
# NOTES: This config file provides you with some example command definitions
#        that you can reference in host, service, and contact definitions.
#        You don't need to keep commands in a separate file from your other
#        object definitions.  This has been done just to make things easier to
#        understand.
# SAMPLE NOTIFICATION COMMANDS
# These are some example notification commands.  They may or may not work on
# your system without modification.  As an example, some systems will require
# you to use "/usr/bin/mailx" instead of "/usr/bin/mail" in the commands below.
    command_name    notify-host-by-email
    command_line    /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /bin/mail -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
    command_name    notify-service-by-email
    command_line    /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$\n" | /bin/mail -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
# SAMPLE HOST CHECK COMMANDS
# This command checks to see if a host is "alive" by pinging it
# The check must result in a 100% packet loss or 5 second (5000ms) round trip
# average time to produce a critical error.
# Note: Five ICMP echo packets are sent (determined by the '-p 5' argument)
    command_name    check-host-alive
    command_line    $USER1$/check_ping -H $HOSTADDRESS$ -w 3000.0,80% -c 5000.0,100% -p 5
# SAMPLE SERVICE CHECK COMMANDS
# These are some example service check commands.  They may or may not work on
# your system, as they must be modified for your plugins.  See the HTML
# documentation on the plugins for examples of how to configure command definitions.
# NOTE:  The following 'check_local_...' functions are designed to monitor
#        various metrics on the host that Nagios is running on (i.e. this one).
    command_name    check_local_disk
    command_line    $USER1$/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$
    command_name    check_local_load
    command_line    $USER1$/check_load -w $ARG1$ -c $ARG2$
    command_name    check_local_procs
    command_line    $USER1$/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
    command_name    check_local_users
    command_line    $USER1$/check_users -w $ARG1$ -c $ARG2$
    command_name    check_local_swap
    command_line    $USER1$/check_swap -w $ARG1$ -c $ARG2$
    command_name    check_local_mrtgtraf
    command_line    $USER1$/check_mrtgtraf -F $ARG1$ -a $ARG2$ -w $ARG3$ -c $ARG4$ -e $ARG5$
# NOTE:  The following 'check_...' commands are used to monitor services on
#        both local and remote hosts.
    command_name    check_ftp
    command_line    $USER1$/check_ftp -H $HOSTADDRESS$ $ARG1$
    command_name    check_hpjd
    command_line    $USER1$/check_hpjd -H $HOSTADDRESS$ $ARG1$
    command_name    check_snmp
    command_line    $USER1$/check_snmp -H $HOSTADDRESS$ $ARG1$
    command_name    check_http
    command_line    $USER1$/check_http -I $HOSTADDRESS$ $ARG1$
    command_name    check_ssh
    command_line    $USER1$/check_ssh $ARG1$ $HOSTADDRESS$
    command_name    check_dhcp
    command_line    $USER1$/check_dhcp $ARG1$
    command_name    check_ping
    command_line    $USER1$/check_ping -H $HOSTADDRESS$ -w $ARG1$ -c $ARG2$ -p 5
    command_name    check_pop
    command_line    $USER1$/check_pop -H $HOSTADDRESS$ $ARG1$
    command_name    check_imap
    command_line    $USER1$/check_imap -H $HOSTADDRESS$ $ARG1$
    command_name    check_smtp
    command_line    $USER1$/check_smtp -H $HOSTADDRESS$ $ARG1$
    command_name    check_tcp
    command_line    $USER1$/check_tcp -H $HOSTADDRESS$ -p $ARG1$ $ARG2$
    command_name    check_udp
    command_line    $USER1$/check_udp -H $HOSTADDRESS$ -p $ARG1$ $ARG2$
    command_name    check_nt
    command_line    $USER1$/check_nt -H $HOSTADDRESS$ -p 12489 -v $ARG1$ $ARG2$
# SAMPLE PERFORMANCE DATA COMMANDS
# These are sample performance data commands that can be used to send performance
# data output to two text files (one for hosts, another for services).  If you
# plan on simply writing performance data out to a file, consider using the
# host_perfdata_file and service_perfdata_file options in the main config file.
    command_name    process-host-perfdata
    command_line    /usr/bin/printf "%b" "$LASTHOSTCHECK$\t$HOSTNAME$\t$HOSTSTATE$\t$HOSTATTEMPT$\t$HOSTSTATETYPE$\t$HOSTEXECUTIONTIME$\t$HOSTOUTPUT$\t$HOSTPERFDATA$\n" >> /usr/local/nagios/var/host-perfdata.out
    command_name    process-service-perfdata
    command_line    /usr/bin/printf "%b" "$LASTSERVICECHECK$\t$HOSTNAME$\t$SERVICEDESC$\t$SERVICESTATE$\t$SERVICEATTEMPT$\t$SERVICESTATETYPE$\t$SERVICEEXECUTIONTIME$\t$SERVICELATENCY$\t$SERVICEOUTPUT$\t$SERVICEPERFDATA$\n" >> /usr/local/nagios/var/service-perfdata.out
ExampleHost.cfg
define host {
    host_name         Server
    alias                  Test Server
    address                172.16.2.14
    max_check_attempts     3
    check_period           24x7
    check_command          check-host-alive
    contact_groups         admins
    notification_interval  60
Templates.cfg
# TEMPLATES.CFG - SAMPLE OBJECT TEMPLATES
# NOTES: This config file provides you with some example object definition
#        templates that are referred by other host, service, contact, etc.
#        definitions in other config files.
#        You don't need to keep these definitions in a separate file from your
#        other object definitions.  This has been done just to make things
#        easier to understand.
# CONTACT TEMPLATES
# Generic contact definition template
# This is NOT a real contact, just a template!
define contact {
    name                            generic-contact         ; The name of this contact template
#    service_notification_period     24x7                    ; service notifications can be sent anytime
     host_notification_period        24x7                    ; host notifications can be sent anytime
#    service_notification_options    w,u,c,r,f,s             ; send notifications for all service states, flapping events, and scheduled downtime events
     host_notification_options       d,u,r,f,s               ; send notifications for all host states, flapping events, and scheduled downtime events
#    service_notification_commands   notify-service-by-email ; send service notifications via email
     host_notification_commands      notify-host-by-email    ; send host notifications via email
    register                        0                       ; DON'T REGISTER THIS DEFINITION - ITS NOT A REAL CONTACT, JUST A TEMPLATE!
# HOST TEMPLATES
# Generic host definition template
# This is NOT a real host, just a template!
define host {
    name                            generic-host            ; The name of this host template
    notifications_enabled           1                       ; Host notifications are enabled
    event_handler_enabled           1                       ; Host event handler is enabled
    flap_detection_enabled          1                       ; Flap detection is enabled
    process_perf_data               1                       ; Process performance data
    retain_status_information       1                       ; Retain status information across program restarts
    retain_nonstatus_information    1                       ; Retain non-status information across program restarts
    notification_period             24x7                    ; Send host notifications at any time
    register                        0                       ; DON'T REGISTER THIS DEFINITION - ITS NOT A REAL HOST, JUST A TEMPLATE!
# Linux host definition template
define host {
    name                            linux-server            ; The name of this host template
    use                             generic-host            ; This template inherits other values from the generic-host template
    check_period                    24x7                    ; By default, Linux hosts are checked round the clock
    check_interval                  5                       ; Actively check the host every 5 minutes
    retry_interval                  1                       ; Schedule host check retries at 1 minute intervals
    max_check_attempts              10                      ; Check each Linux host 10 times (max)
    check_command                   check-host-alive        ; Default command to check Linux hosts
    notification_period             workhours               ; Linux admins hate to be woken up, so we only notify during the day
                                                            ; Note that the notification_period variable is being overridden from
                                                            ; the value that is inherited from the generic-host template!
    notification_interval           120                     ; Resend notifications every 2 hours
    notification_options            d,u,r                   ; Only send notifications for specific host states
    contact_groups                  admins                  ; Notifications get sent to the admins by default
# Windows host definition template
define host {
    name                            windows-server          ; The name of this host template
    use                             generic-host            ; Inherit default values from the generic-host template
    check_period                    24x7                    ; By default, Windows servers are monitored round the clock
    check_interval                  5                       ; Actively check the server every 5 minutes
    max_check_attempts              10                      ; Check each server 10 times (max)
    check_command                   check-host-alive        ; Default command to check if servers are "alive"
    notification_period             24x7                    ; Send notification out at any time - day or night
    notification_interval           30                      ; Resend notifications every 30 minutes
    notification_options            d,r                     ; Only send notifications for specific host states
    hostgroups                      windows-servers         ; Host groups that Windows servers should be a member of
    register                        0                       ; DON'T REGISTER THIS - ITS JUST A TEMPLATE
# We define a generic printer template that can
# be used for most printers we monitor
define host {
    name                            generic-printer         ; The name of this host template
    check_period                    24x7                    ; By default, printers are monitored round the clock
    check_interval                  5                       ; Actively check the printer every 5 minutes
    max_check_attempts              10                      ; Check each printer 10 times (max)
    check_command                   check-host-alive        ; Default command to check if printers are "alive"
    notification_period             workhours               ; Printers are only used during the workday
# Define a template for switches that we can reuse
define host {
    name                            generic-switch          ; The name of this host template
    check_period                    24x7                    ; By default, switches are monitored round the clock
    check_interval                  5                       ; Switches are checked every 5 minutes
    max_check_attempts              10                      ; Check each switch 10 times (max)
    check_command                   check-host-alive        ; Default command to check if routers are "alive"
    notification_period             24x7                    ; Send notifications at any time
# SERVICE TEMPLATES
# Generic service definition template
# This is NOT a real service, just a template!
    name                            generic-service         ; The 'name' of this service template
    active_checks_enabled           1                       ; Active service checks are enabled
    passive_checks_enabled          1                       ; Passive service checks are enabled/accepted
    parallelize_check               1                       ; Active service checks should be parallelized (disabling this can lead to major performance problems)
    obsess_over_service             1                       ; We should obsess over this service (if necessary)
    check_freshness                 0                       ; Default is to NOT check service 'freshness'
    notifications_enabled           1                       ; Service notifications are enabled
    event_handler_enabled           1                       ; Service event handler is enabled
    is_volatile                     0                       ; The service is not volatile
    check_period                    24x7                    ; The service can be checked at any time of the day
    max_check_attempts              3                       ; Re-check the service up to 3 times in order to determine its final (hard) state
    check_interval                  10                      ; Check the service every 10 minutes under normal conditions
    retry_interval                  2                       ; Re-check the service every two minutes until a hard state can be determined
    contact_groups                  admins                  ; Notifications get sent out to everyone in the 'admins' group
    notification_options            w,u,c,r                 ; Send notifications about warning, unknown, critical, and recovery events
    notification_interval           60                      ; Re-notify about service problems every hour
    notification_period             24x7                    ; Notifications can be sent out at any time
    register                        0                       ; DON'T REGISTER THIS DEFINITION - ITS NOT A REAL SERVICE, JUST A TEMPLATE!
# Local service definition template
    name                            local-service           ; The name of this service template
    use                             generic-service         ; Inherit default values from the generic-service definition
    max_check_attempts              4                       ; Re-check the service up to 4 times in order to determine its final (hard) state
    check_interval                  5                       ; Check the service every 5 minutes under normal conditions
    retry_interval                  1                       ; Re-check the service every minute until a hard state can be determined
    register                        0                       ; DONT REGISTER THIS DEFINITION - ITS NOT A REAL SERVICE, JUST A TEMPLATE!
Timeperiods.cfg
# TIMEPERIODS.CFG - SAMPLE TIMEPERIOD DEFINITIONS
# NOTES: This config file provides you with some example timeperiod definitions
#        that you can reference in host, service, contact, and dependency
#        definitions.
#        You don't need to keep timeperiods in a separate file from your other
#        understand.
# TIMEPERIOD DEFINITIONS
# This defines a timeperiod where all times are valid for checks,
# notifications, etc.  The classic "24x7" support nightmare. :-)
define timeperiod {
    name                    24x7
    timeperiod_name         24x7
    alias                   24 Hours A Day, 7 Days A Week
    sunday                  00:00-24:00
    monday                  00:00-24:00
    tuesday                 00:00-24:00
    wednesday               00:00-24:00
    thursday                00:00-24:00
    friday                  00:00-24:00
    saturday                00:00-24:00
# This defines a timeperiod that is normal workhours for
# those of us monitoring networks and such in the U.S.
define timeperiod {
    name                    workhours
    timeperiod_name         workhours
    alias                   Normal Work Hours
    monday                  09:00-17:00
    tuesday                 09:00-17:00
    wednesday               09:00-17:00
    thursday                09:00-17:00
    friday                  09:00-17:00
# This defines the *perfect* check and notification
# timeperiod
define timeperiod {
    name                    none
    timeperiod_name         none
    alias                   No Time Is A Good Time
# Some U.S. holidays
# Note: The timeranges for each holiday are meant to *exclude* the holidays from being
# treated as a valid time for notifications, etc.  You probably don't want your pager
# going off on New Year's.  Although your employer might... :-)
define timeperiod {
    name                    us-holidays
    timeperiod_name         us-holidays
    alias                   U.S. Holidays
    january 1               00:00-00:00     ; New Years
    monday -1 may           00:00-00:00     ; Memorial Day (last Monday in May)
    july 4                  00:00-00:00     ; Independence Day
    monday 1 september      00:00-00:00     ; Labor Day (first Monday in September)
    thursday 4 november     00:00-00:00     ; Thanksgiving (4th Thursday in November)
    december 25             00:00-00:00     ; Christmas
# This defines a modified "24x7" timeperiod that covers every day of the
# year, except for U.S. holidays (defined in the timeperiod above).
define timeperiod {
    name                    24x7_sans_holidays
    timeperiod_name         24x7_sans_holidays
    alias                   24x7 Sans Holidays
    use                     us-holidays     ; Get holiday exceptions from other timeperiod
    sunday                  00:00-24:00
    monday                  00:00-24:00
    tuesday                 00:00-24:00
    friday                  00:00-24:00
Post Reply
