Sendmail
noodle48
Sendmail
Post by noodle48 »
I wanted to know if there was a sendmail plugin. I have a server running the sendmail process and just need a check to make sure if its up and running. I can't seem to find a good sendmail plugin. The server I need to monitor will be running AIX 5.3. All I would really need is a ps -ef | grep sendmail type of plugin. Any help would be greatly appreciated.
jeff.chung
Re: Sendmail
Post by jeff.chung »
I use the check_smtp plugin. It is better than just checking to make sure there is a sendmail process running.
http://nagiosplugins.org/man/check_smtp
agriffin
Re: Sendmail
Post by agriffin »
The check_email_delivery plugin will monitor the whole delivery process. It not only checks that the server is responding correctly, but also that mail can be sent and received successfully.
Otherwise, check_procs is the plugin that you described in your post, if all you really want is to make sure the process is running. It's a standard Nagios plugin.
noodle48
Re: Sendmail
Post by noodle48 »
Thanks I will use the snmp plugin. Also, with this plugin is there a way I can have it monitor just 1 host under a hostgroup or will I need to create another hostgroup?
noodle48
Re: Sendmail
Post by noodle48 »
Will open another thread.
