Interval length in XI
Post Reply
timchin
Post by timchin »
Hi there. What is the preferred way to change the interval length in XI? I know some config files get overridden by the config mgr.
Also, does the UI reflect the change if < 60? For example: The UI says 'min' -- Does it change to seconds if the interval length is set to 1 or 30?
Please advise. Thx
Tim
ajcoil
Re: Interval length in XI
Post by ajcoil »
Hi @timchin,
Thank you for reaching out!
To provide better assistance, is there a particular interval length you are referring to?
Post Reply
