Install NRPE failed
Post Reply
swddels
Install NRPE failed
Post by swddels »
Hi, i follow the installation guide
https://assets.nagios.com/downloads/nag ... _Agent.pdf
but failed, please help, thanks!
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './A-subcomponents'
ajcoil
Re: Install NRPE failed
Post by ajcoil »
Hi @swddels,
Thank you for reaching out!
I'm sorry to hear you are having installation issues with installing NRPE.
I would recommend installing the latest version from https://assets.nagios.com/downloads/nag ... ent.tar.gz.
If you are still having issues, feel free to reach out!
kg2857
Post by kg2857 »
I think newer nrpe installs set nrpe as a service rather than running under xinetd. That said, has the OP thought to read the error messages, check if xinettd is isn installed and maybe setting it up?
Post Reply
